The ability to place a Custom symbol on a Surface using the "Normal to Entity" placement type in 3D.
Currently there is no Placement option for "Normal to Entity" when placing symbols in 3D.
For example, this would be handy when placing surface finishes directly onto dimension witness lines or the applicable surfaces in 3D.
1 Comment
Visitor
This would greatly improve the use of surface finish.
In the past PTC advised the use of symbols instead of using the build-in surface finish.
