The ability to set models to Maximum Material and Least Material Conditions
When creating a Creo model most models are created at nominal dimensions and then tolerances are applied as defaults or explicitly.  Given the linear tolerances that are applied it should be simple to have Creo step to a "state" where the dimensions go to a limit of the tolerance and then regenerate the model.
2 Comments
psobejko
You can do this already.  Go to Analysis Tab, then in the Tolerance Analysis in the Design Study group, select Dimension Boundaries.
PTCModerator
Emeritus
Status changed to: Archived
