Now in drawing in Creo Parametric you can't make an associative link to balloon into the note (if you don't have Windchill, but even if you have Windchill it is so inconvinient to do).
It will be cool when you work with notes in drawing just click on the component of assembly (from the tree, for example) and have his number of balloon into your text..
