Virtually any feature that requires the use of a shift key is a waste of time, effort and slows you down.
Drag handles on dimensions in the drafting environment...Now I have to use the shift key? Ridiculous. You've taken a step backwards.
Accessing the properties only by double-selecting the extension lines makes it more difficult.
Measuring features is now a pain in the rear.
Thank you so much to the programmers who obviously have never actually spent any time designing parts in real life.
Kudos!
