The drawing setup option half_section_line allows to set centerline but its length cannot be changed
The drawing setup option half_section_line allows to set centerline but its length cannot be changed.
I should be possible to change the length of the centerline.
3 Comments
mender
6-Contributor
Clarifying question, are you looking to change the offset from the edge of the geometry to the end of the line in a global manner (i.e. a dtl setup option saying 'where it is usually 1/2 inch, I'd like 1 inch') or to have the ability to drag the ends?
grichter
3-Visitor
Thank you Matthew.
I´m looking to change the offset from the edge of the geometry to the end of the line in a global manner (i.e. a dtl setup option)
olivierlp
Community Manager
Status changed to: Archived
