Currently, only one IMAGE is created in the PDF export from the 3D model.
In order to use the MBD functionality, it is also necessary to influence the representation of the export formats.
When creating the PDF from the 3D data, the same functionality should be available as in the 2D drawing like the pentable.pnt file.
