The "Show Docuplane" command should not change the visibility of the free Annotations.
The action behind the browser double clicking a docuplane is "Show Docuplane". This action shows the selected docuplane, changes the view orientation parallel to the docuplane, and shows OFF the all free Annotations.
This behavior is OK for Modeling. But the change of visibility of free annotations causes the modify flag ON.
In Model Manager, it means this model shoud be saved. Model Manager customers confuse if they should save the model or not.
I would like to remove "Show OFF free Annotations" from "Show Docuplane" command.
