The way to move notes and dimension should be the same
Since Creo 2.0, the way to move horizontally a dimension and a note is different
- for the dimension, SHIFT button need to be used
- for the note,  dragger need to be used
This is very disturbing for the user.
The note and dimension should be moved in the same way
The best solution should be to have the possibility to use either the SHIFT button or either the dragger for note and dimension
3 Comments
Newbie
Olivier,
About two weeks ago I needed to move a dimension laterially and didn't know about pressing "shift" and dragging.  I went through a 5 click sequence to do that.  Thanks for identifing a much simplier method.  I like the idea of standardizing their interface.
Aquamarine
My related idea:
Re-add leader grab points for dimensons
http://communities.ptc.com/ideas/3534
Community Manager
