The way to move notes and dimension should be the same
Since Creo 2.0, the way to move horizontally a dimension and a note is different
- for the dimension, SHIFT button need to be used
- for the note,  dragger need to be used
This is very disturbing for the user.
The note and dimension should be moved in the same way
The best solution should be to have the possibility to use either the SHIFT button or either the dragger for note and dimension
4 Comments
IceDog
1-Newbie
Olivier,
About two weeks ago I needed to move a dimension laterially and didn't know about pressing "shift" and dragging.  I went through a 5 click sequence to do that.  Thanks for identifing a much simplier method.  I like the idea of standardizing their interface.
dhermosillo
My related idea:
Re-add leader grab points for dimensons
http://communities.ptc.com/ideas/3534
PTCModerator
Emeritus
Mfridman
Status changed to: Current Functionality
Since Creo 4.0 it is possible to horizontally move both a dimension and a note when pressing the SHIFT key.
In addition the note have an extra handle for the elbow that will allow the user to make sure that the note text is in place while the note leader changes its position
