Currently there's no opening when updating a Drafting titleblock using the Windchill Workgroup Manager.
Something simple as putting the drawing scale in the titleblock is therefore not possible.
In WorkManager/Model Manager, you had a macro updating the titleblock.
You had the possibility to edit/overwrite the macro so you could perform actions before or after the titleblock update.
This could be used for example to retrieve the Drawing Scale, and put an extra attribute to the "tb" textreference table (now "WTtr").
This attribute would then be automatically filled in the titleblock.
