Thickness Analysis
Thickness Analysis
When using the thickness analysis tool it would be very helpful if you could change the traspaency of a colour. This would then allow you to see into a model and view features that would otherwise be obscured by the solid colours that are used at the moment.
The only real way of viewing internal features at the moment is with cross sections.
3 Comments
rireland-bowcot
11-Garnet
No, I am talking about when you are checking wall thicknesses in the analysis tab.
As you can see in the screenshot. I am having to apply a cross section to see interior features. Whereas if I could change the transparency of the colour that represents thicknesses within the  tolerence I could see into the model.
Marco_Tosin
Rory, you have to vote up your idea, because the system doesn't automatically for you when you create an idea.
PTCModerator
Emeritus
Status changed to: Archived
