Threaded Hole Enhancement:
Create a standard feature type, similar to threaded hole, which incorporates a simple extrude and a threaded hole to create the standard "threaded boss" feature with sequence of placement and reference handles.
Options to include:
Boss shape: square, rounded corner square, round
Top options: flat top, fully rounded top
The current solution in Creo 4 M060 (and our corporation is not on it yet, but will be the same in the latest Creo 7 version as well) is to either copy the features or use a User Defined Feature to re-create them across models, however these options do not provide the ease of use and modification that the standard hole type feature could.
Use Case:
These kind of features can be repeated 100 times in a finished casting model, varying size, thread size, shape, etc.
