Case: Proe linked to MDM and PDM software (Windchill). All provided by PTC
The PDM software is the reference. It manages the BOM. In this case the BOM hasn't to be anymore on the drawing to avoid to duplicate the BOM and to risk to share two BOMs with differents contents.
If a designer has a legacy drawing with a BOM table and several BOM balloons, he needs to remove the BOM table but keeping the BOM balloons before to link, to publish the drawing to the PDM software.
Actually, if he deletes the BOM table, all the BOM balloons are deleted. He has to place again one by one. He spends a lot of time. Wasted time...
With an option in the function BOM, he could "disconnect", make independent the BOM Balloons and the BOM table. Then he will be able to delete the table and keep all the balloons. Won time
