To implement in Creo 4 IDX version output to be 3.5 to increases ECAD and MCAD
Currently in Creo 4 and even in Creo 6 the output version for IDX is 3.0.
In our organization we are loosing mainly feature that enable :
Rigid/Flex Support
Bend Area/Bend Line
The standards for IDX from ECAD-MCAD org improves and promote  to have 3.5 version to : have higher level of quality and includes features like:
Comparing IDX 3.5 vs. IDF 3.0: http://www.ecad-mcad.org/index.html#why-collaborate
Object
Incremental Changes
Accept / Reject Changes
Comments on Changes/File level
Change History Tracking
Board Outline
Stackup Structure
Multiple Stackups
Board Cut-outs
Cavities
User Defined outlines/areas
Components (Loc, orientation)
Component Height (multiple shapes)
Holes (Circular)
Holes (non-Circular)
Route Keep-in/Keep-out
Place Keep-in/Keep-out
Place Room Region
Via Keep-out
Voids in Keep-outs
Traces and Pads on all layers (One Direction)
Copper Shapes (Bi-directional)
Vias (Through)
Vias (Blind/Buried)
Embedded Components
Pin 1 Location
Rigid/Flex Support
Bend Area/Bend Line
Object Ownership
Refdes resequencing support
Without the 3.5 IDX version we are loosing a lot of advantage for the ECAD - MCAD collaboration.
Hope this could be implemented soon
Kind Regards,
Mario Martinez
4 Comments
JoshuaHouser
Would be nice to know when IDX 3.5 is planned @JimBarrettSmith Smiley Very Happy
tshen
It seems Creo currently supports some object in IDX 3.5 on creo side,
for example,
About the comparing IDX 3.5 vs. IDF 3.0, please access the following link for detail:
Ruediger_Scholz
Hi all,
I think the comparison is a little bit misleading, as it compares IDX 3.5 with IDF 3.0. IDF 3.0 is an over 20 year old specification. IDF itself has some short comings in the collaboration, which was one of the reason for Prostep / PTC and Mentor to develop the new IDX format.  Now, the difference between IDX 3.5 and IDX 3.0 is rather smalls (at least from an end-user perspective): IDX 3.0 already supports almost all of the mentioned features of IDX 3.5 in above table (not sure about cooper support).
Best,
Ruediger
P.S. Most ECAD application I am aware of support IDX 3.0.
Alex_Y
Status changed to: Duplicate
Hi @mmartinez ,
As I answered in a different post, supporting newer IDX versions does not mean supporting everything they have to offer.
We will support IDX 4.5 import and export in the near future but full support of Rigid-Flex is a large project that I am looking to do as soon as we will have the needed infrastructure in place. It's a high priority project for us.
