If we want to get more information from the drawing into the model, it should be able to place symbols to annotations (to model dimensions, notes or other symbols).
Keyword: Model Based Definition.
The inspection boundary with its detail of 99.73% is a symbol (see picture below).
This symbol should refer to the dimension which belongs to.
If the dimension is moved, the symbol must be followed the dimension (to create this condition with Creo 2.0 m080 is not possible).
Thanks in advance for the consideration
Best Regards
Knut Schäfer
