Toggle display of state names, and where to display them.
If a layer state is defined, it is displayed in the lower left corner.  Same for simplified reps, x-sections, clipping, etc.  This display needs a toggle other than temporary shade.
Also, GD&T Advisor automatically puts notes in the bottom left corner, which overlap these state displays.  Therefore the location of the state displays should be configurable so they can be moved to, for example, the lower right corner, above or below the tolerance display.
