Toolkit APIs for ECAD MCAD collaboration: import and export ECAD native files, IDF and so on
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
PCB design, computer and electronic device design
We are Design Automation Team.
Our customers are our MCAD Mechanical designers, ECAD designers, product designers.
2. What version of Creo Parametric are you currently running?
Creo 9.0, and Creo 7.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We want to help Creo users to faster and easier import and export files for ECAD-MCAD collaboration. e.g.: import native ECAD IPC-2581 files, IDF file and so on.  Currently, the process is a manual process because there is no API available and map keys do not work properly and reliable.
4. What is the use case for your organization?
The design automation to auto import IPC-2581 files in Creo, and auto export IDF files from Creo.
5. What business value would your suggestion represent for your organization?
It will add significate values to our current design workflow. Make it more reliable, faster and easier for designers.
1 Comment
achirila
Moderator
Hi @CF_10185996 and welcome to the PTC Community!
Thank you for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
