Toolkit - Control and Change Combined States in the tabs at the bottom of the Screen
Currently it is not possible to adjust the order of the Combined States in the Tabs at the bottom of the screen with the Toolkit API. It would be nice if there was a way to change the order of Combined States in the Tabs at the bottom of the Screen and to control if all needed Combined States are displayed in the Tabs with Toolkit.
This can be controlled manually in the View Manager with the Tab Display column.
2 Comments
Mfridman
aazkue
9-Granite
Related to this idea, it would be necessary to maintain the same order of the Combined States in both Creo Parametric and Creo View (with the .pvz format).
