So far, there is no Toolkit function to update the restriction definition of parameters.
There is only a workaround by using macros (see also PTC article CS235369).
However, the use of macros is not version safe: A macro that works in Creo 7.0 may not work in Creo 8.0.
Therefore, I would like to have a corresponding Toolkit function!
