Toolkit functions to deal with Repeat Regions on drawings
Currently, there are no Toolkit functions for Repeat Regions on drawings, to
  • sort,
  • filter,
  • fix indexes
Even setting a Repeat Region in a drawing table is not possible (see CS157928).
Please provide some more Toolkit functions, to deal with Repeat Regions!
4 Comments
DougFriggstad
1-Newbie
Please provide repeat region relation support ASAP.... please, please, please!  While working on that, provide filter and attribute control.  Suggest you should cover everything.  I have been using trail files to select the region followed by C++ generated macros to accomplish the task... is very silly but is the only way to deal with PTC shortfall.
PTCModerator
Emeritus
Jaime_Lee
Community Manager
  • sort,
  • filter,
  • fix indexes
mfischer
18-Opal
Status changed to: Under Consideration
While the Toolkit libraries (C, C++, Java Object Toolkit) are extensive they do not cover all areas or may be limited in certain areas of Creo.  Repeat Regions is one such area that we have limited a set of API's.  With each release of Creo, we strive to reduce these gaps across Creo, allowing users that would like to customize Creo to have access to a wider range of APIs.  I have added this area to the list to address in a future release of Creo.
Mark Fischer
Sr. Director, CAD Product Management
