It would be awesome to see in the paste special menu when copying a quilt in part mode, the ability to transform a quilt or surface's location by selecting an origin and target coordinate system. Current transformations are limited to translate and rotate, which makes it difficult to stay parametric to underlying geometry.
Coordinate system placement is used in many other areas of Creo (assembly, UDF's, publish geom) and it needs to also go in part mode within the paste special menu.
