Create one button that toggles between transparent and solid in an assembly
Are you looking to change a part or sub-assembly between transparent and solid? I have added those buttons to my mouse shortcut menu.
I also have a mapkey.
Mine will not toggle off only on.
The buttons are not toggles, as there are several possible rendering styles. The right button is for shaded display.
Just make it one button....
You could add the drop down menu to the menu.
They could change all of the model display buttons into toggles that override the programs view settings.
That would be alright
