It would be useful to have an option to make the faces which intersect a cross-section transparent. I frequently want to see 'behind' a face, so select it for a section view, but the view still displays the geometry which is incident with it.
For example, when arranging the contents of a container it is useful to see behind the internal wall faces. However, to achieve this in practice requires selecting a plane which is infinitesimally offset from the desired plane.
