Turn drawing dimensions unregenerated when the reference is no longer viewable in the drawing. Or at least create an option to make drawing dimensions behave this way.
Example of current functionality. Part created with an extrude, create a drawing dimension showing the length of extrude.
Next create a second extrude that cuts one of the ends off or add material . Notice how dimension stays YELLOW (Regenerated). Dimension in GREEN shown to show the change.
This is a major issue. There's NO indicator for someone cleaning up the drawing to know the 30.000 dimension is wrong. Very easy for parts to be scrapped because of this.
Please vote for this idea.
