Turning: feed definition similar to machining allowance
For machining allowances, a definition of the values for each section of the turning profile is possible.
This is currently not possible for the feeds.
However, the current procedure with CL commands has several disadvantages.
In the definition relative to the tool movement, the position of the feed changes with each change of the rotary profile.
The definition relative to geometics is very tricy for single profiles.
In addition, it is difficult to catch edges.
It should not be too complicated to implement this feature, the logic is similar to the dimensions.
25000092628_MF01 Rev_ 00.7+ Wird bearbeitet  (Aktiv) wtws___MDT_01_Test_25000092.jpgCL-Befehl.jpg
2 Comments
OS_7883567
11-Garnet
This would be very helpful!
It isn't very reliable with the current function. In case i change the turn profile afterwards, it shifts the setpoint from the manual command (due to the function "relative to tool motion")...
olivierlp
Community Manager
Status changed to: Archived
