Type of variable text set in Symbol Definition Attributes (Text, Integer, Floating Point)
0 Kudos
I want to know the type of variable text set in Symbol Definition Attributes of symbol instance through Toolkit. I could only find APIs related to set and get variable text of symbol instance using APIs ProDtlsyminstdataVartextsSet(), ProDtlsyminstdataVartextsCollect(), and ProDtlvartextDataGet(). However, I don’t see any API to query the type of variable text set.
This is required in some cases if I want to compare the old symbol with any new symbol where i have changed the type from integer to text.
