Article - CS160646
Performance issue with Creo Parametric 2.0 during STEP import with confusing warning message "Creo not responding"
PTC R&D said,
The message 'Creo not repsonding' is a long-standing message. If Creo cannot respond because it is doing work/computations.
So,
I hope the Creo UI will be improved so I can see the progress.
Thank you.
