Security Alert Log4j Security Vulnerability. Click here to know more.
USE_SHEET_SETTINGS tolerance configurable
When USE_SHEET_SETTINGS is ON the format and orientation per sheet is automatically selected based on the sheet size. If standard paper format cannot be matched default paper size(paper size set in dialog in paper format field) is set. Matching tolerance is fixed 3%
When sheet size differs more than 3% from a standard paper size the sheet is printed to pdf without borders. By configuring the tolerance this can be solved.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
