Unable select an Axis of Revolution when this is not on same plane of the sketched section geometry
I found a limitation in the Creo Parametric software already present from the first version and was never implemented.
In the wood tools word where everything revolves around an axis, I find a Creo Parametric limitation:
I can't create a revolution (surface, solid, removal, etc.) if the axis is not on the same plane as the sketch.
PCT esupport replied that it is not a problem but it is an implementation. So if someone else had this need I ask you to report it and expand this discussion so that it can be taken into consideration by the PTC staff.
Christopher S.TWT srl
4 Comments
Flabulus
1-Newbie
I need this implementation too!
It would be great to have. I didn't found any good solution about this.
Please, do this implementation.
Flavio B.
TER srl
C_Spagnolli
Hi Flavio,
the Creo technical staff have to develop it, but I don't know how to request this upgrade.
I contacted technical support but they replied that they do not upgrade but only fault.
C_Spagnolli
I'm still hoping for this change.
How can I get the request to PTC staff?
StephenW
23-Emerald II
The Official way to propose an enhancement is what you have done, you've posted it as an product idea.
There are other methods, such as joining a technical committee https://www.ptcuser.org/Committees/About-Technical-Committees
