Unable to select sketched Datum points for spot weld feature
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Industry: Electrical equipment Design. Role: MCAD Support
2. What version of Creo Parametric are you currently running?
Creo Parametric 8.0.4.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Unable to use/select datum points inside a sketch while creating Spot weld. Creating datum points outside the context of a sketch limits you to how you can constrain the points, so creating a datum point inside a sketch is the desired method.
4. What is the use case for your organization?
Creating pattern of datum points at sketch level and select sketched datum points for the spot weld feature
5. What business value would your suggestion represent for your organization?
Design engineers need not have to create datum point outside the sketch and have flexibility to create point pattern, also easy constraining of points, which saves users extra time.
2 Comments
achirila
Moderator
Status changed to: Clarification Needed
Hi @mahesh_jadhav!
Thank you for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
2. What product & version are you currently running?
Here are a few examples of well documented ideas:
Improve/fix the sheetmetal mirror feature - PTC Community
[Eztol] Rename action not synchronous in Eztol - PTC Community
Always enable ability to 'Add View Label' in a dra... - PTC Community
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
achirila
Moderator
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
