Units management when exporting in U3D PDF
When exporting in U3D PDF, there is no option available to chose the units or use the CREO model units. All U3D PDF are created in meters regardless the model units in CREO. This can give some scalling issue using U3D PDF in other software. An option in UI or and the config.pro to use the model units or to select a given units will be very help full. Why use meter when the CREO model is in millimeters.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
