It is very complicated to untrim surface. I mean to remove triming boundary line completely or only its portion. As inside option I see switch with possibility to keep or delete original surface.
Partially it is already possible to do something similar (only inside untrim) by "remove surface" button it can be good idea to have the same button for all remove or delete operations.
