The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Update of the flat pattern dimensions in the information window
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
SOCOMEC electrical equipment manufacturer.  Mechanical Engineer.
2. What version of Creo Parametric are you currently running?
Creo 8.0.3.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
In the sheet metal module when I modify the dimensions of a part the dimensions of the flat pattern in the information window do not update while in the  flatness preview the dimensions are up to date.
4. What is the use case for your organization?
We retrieve these dimensions in a Java program
5. What business value would your suggestion represent for your organization?
These dimensions are necessary to send this data to our erp
1 Comment
olivierlp
Community Manager
Thank you for your idea and the information provided.
