Geometry of the Flexible Component is not populated into the Cut-Out and Merge features. Flexibility of the Components is ignored.
In my opinion this is a big restriction of the usage of flexible components!
Regarding to this issue, already a CS with an "Enhancement SPR" has been created: https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS143393.
So I really would appreciate, if you vote for this idea!
