Use SI-units and prefix in Creo Parametric
Today, SI-based devices and prefixes are not in use.
See the example in the attached picture.
Suggestion:
Change MM^2 to mm²
Change MM^3 to mm³
Change MM to mm
Change KILOGRAM / MM ^ 3 to kilogram/mm³ or kg/mm³
and so on.
M= mega = 1 000 000
m= milli = 0.001
This is a quite big issue for engineers from whole world outside United states.
 Also see:
https://en.wikipedia.org/wiki/SI_base_unit
https://en.wikipedia.org/wiki/Metric_prefix
Best Regards Per Forsman
per.forsman@strongpoint.com
3 Comments
PerForsman
6-Contributor
Forgot to attatch the picture....
BenLoosli
23-Emerald II
Vote up your own idea!
YES, metric nomenclature is lowercase, per standards.
PTC make your system conform to industry and national standards!!!
PTCModerator
Emeritus
