Use consistent rules regarding display of "state text" overlaid on graphics window
0 Kudos
There are various tabs in the "View Manager" dialog, and text appears overlaid on the bottom of the graphics window depending on which option you have selected for various tabs. Text disappears only if a particular option is selected, and this behavior is not consistent, but it would be desirable if it was.
Current behavior:
  • Simp Rep: text is shown for "Default Rep", but is hidden for "Master Rep"
  • Style: text is shown for "Default Style", but is not shown for "Master Style"
  • Layers: text is shown whenever a layer state is activated. Text will remain until currently activated layer state is removed/deleted.
  • Explode: text is shown whenever view is exploded, and is hidden when view is not exploded
  • Orient: no text
  • Appearance: text is shown for "Master Appearance", but is not shown for "Default Appearance"
Desired behavior:
  • Reverse behavior of master & default Appearance, to be consistent with Simp Rep & Style.
  • Provide option to "deactivate" Layer state, so it is not necessary to create and remove a new layer state simply to remove this text.
