Use ctrl+tab to move between windows - current way creates a feature naming bug
In Pro/Creo Elements 5.0, if you have the belwo option set:
...you cannot use ALT characters in feature tree names, because the alt key is used to switch between windows. Switch windows control to ctrl+tab, as is common in most other programs.
2 Comments
JonathanHodgson
11-Garnet
Also, please try to sort out the window order so that inactive Pro/E windows don't keep jumping to the top of the pile.
PTCModerator
Emeritus
Status changed to: Archived
