Use default assembly template when creating a symmetric assembly (save as)
Actually, when creating a symmetric assembly, the default assembly template is not used.
> File > Save as > Save a Mirror Assembly
We cannot add the missing datum before the “Fusion Symmetric”, first function of the model tree.
Please add the check box “Use default template”.
Best regards
Nicolas
01 - first function of the model tree is the “Fusion Symmetric” and the assembly template is not used.jpg
4 Comments
NicolasBourgeoi1
This idea could also be useful for parts
Use default template when creating a symmetric part or assembly (save as)
Awathya
3-Visitor
Not allowed to use the default template set by an organization is impacting MBD since the user is losing MBD schema after creating a new part as a mirror of the existing part.
cbaischer
We spend many hours adding correct relations to the mirrored parts. We need the correct parameters for SAP.
Actually we must add the relations (after the regeneration).
Our mirrored assemblies and subassemblies use up to 150 mirrored parts
e.g.:
/* bei Spiegelbauteilen nachfolgende 2 Beziehungen Auskommentierung entfernen
benennung_1="SPB_zu "+ merge_base_part:FID_1
benennung_2="MIRROR OF "+ merge_base_part:FID_1
ArnaudVandeVeer
Status changed to: Under Consideration
This will be reviewed.
