Actually, when creating a symmetric assembly, the default assembly template is not used.
> File > Save as > Save a Mirror Assembly
We cannot add the missing datum before the “Fusion Symmetric”, first function of the model tree.
Please add the check box “Use default template”.
Best regards
Nicolas
