Use the color functionality of PTC_MATERIAL_NAME to vary color instances
PTC_MATERIAL_NAME parameter uses the material file. You can vary different materials in the family table.
You can also assign colors in materials.
I would think if A=B and B=C then A=C should work, but it doesn't.
Procedure
-Create a material called BLUE and assign a blue color to it and a material called RED and assign a red color to it
-Add them to a Generic and assign PTC_MATERIAL_NAME to vary in the family table
-Create 1 instance that uses the RED material and one that uses the BLUE material
I would think the blue instance would be blue and the red instance red.
However, all parts (generic & instances) will always show the color for the last part that got regenerated.
I know there are other tricks (using surfaces) to fake the color. I'm using them myself. However, they all have their own downside. One downside is if someone references a red surface for mating and then replaces the component to blue. This will fail placement since the blue and red surfaces are different.
Again, since A=B and B=C, then A=C should work.
Please get this working well.
Thank you.
7 Comments
NicolasBourgeoi1
An SPR has been classed as E (enhancement).
Our problem: Only one colored instance can be in session at a time ...
I think that the methodology worked in 2008 (?)
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS33983
PTCModerator
Emeritus
ecrespi
It's time to make color in fmily works as peolple wants
ecrespi
Sorry for my English....
RobertH
Any news about this topic. It is "Acknowledged" but then what?
ptc-2257423
3-Visitor
As with many other issues...no news from PTC 😡
RobertH
They are too busy counting their money they got from the Windchill licenses...
