I think a lot of people, myself included need a BOM table which will display user defined balloon numbers. I don't want the index numbers in the balloons. Ideally, I need a table that I can have the BOM plus a column in which I can define the balloon number required. This would save a lot of time from having to manually create balloon notes with my desired number. Many of us have ancient MRP systems that we must bend to.
