1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
HVAC chiller and compressor R&D , Design engineer , OEM
2. What version of Creo Parametric are you currently running?
Creo Parametric 4.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
In solidworks dimension are aligned correctly but Creo is making some miss alignment
below attached screen shot from solid works
this is creo
4. What is the use case for your organization?
For manufacturing engineer need clear dimension
5. What business value would your suggestion represent for your organization?
