Using machining strategies from ModuleWorks in Creo NC
ModuleWorks provides software components for complex CNC machine motions which require sophisticated algorithms, which are integrated as core components in a CAD/CAM software package. http://www.moduleworks.com . Our customers want more 5 axis strategies. There are 5 axis roughing, impeller strategies, etc. This strategies take into consideration workpiece. It is very important when workpiece has complex geometry. Moluleworks has own simulation module.
Embedded Creo simulation very bad for mill-turn machine. Vericut machine simulation is expensive.
I propose to integrate ModuleWorks solution in Creo NC.
4 Comments
ljin-2
2-Guest
creo 2.0 m210 and creo 3.0 m090 will use moduleworks to replace vericut
skozhinov
3-Visitor
This is not enough. Customers need new NC sequence from moduleworks for machining impellers.
whu-2
Info from Creo Sugar Paul in PTC Liveworx 2017, Creo 5.0 will include 5 axis mold machining from modelworks
olivierlp
Community Manager
Status changed to: Archived
