I would like to see better use of the space taken up by the ribbon when creating features. I am using 4.0 M130 and most of of the feature tabs have a lot of unused ribbon space with no option to modify the ribbon. We are required to open a drop down menu to get to many of the functions of the feature.
Here is an example of the Project feature ribbon. Why not add the type and sketch selection in the empty space. There is even room for the Name field from the properties tab so that I can easily name the feature.
