Over the last 20 years of Pro/ENGINEER and Creo Parametric use, we have accumulated around 100 to 150 "standard" mapkeys in our company-config.pro.
Unfortunately, it is not really possible to track which of these mapkeys are actually used frequently and which are hardly ever used.
Therefore, it would be a great feature if the frequency of mapkey usage could be tracked in Creo Performance Advisor.
This would be a great way to determine which mapkeys have a raison d'être in the central config.pro and which ones could rather be cleaned out.
