We would like to have same View name function of Auxiliary View for Projection View.
As some want these, and some do not, it is configurable. Try the config 'make_proj_view_notes yes', and see if it meets your needs?
Marking this "current functionality" as the config mentioned above (make_proj_view_notes) should resolve the issue.
