If section view , projection view or detail view has been moved to another sheet it should automatically reference the sheet name of the parent view
When views are moved to different sheets, it is sometimes difficult to find which sheet the parent view resides on. When drawings are plotted then this becomes even more difficult unless the views themselves are annotated specifying on which sheet the parent view resides.
So the idea here is that when a view that child of another view is moved to another sheet, the note for that view is automatically updated with a parametric note that specifies the sheet of the parent view. If the sheet of the parent view changes then the note should update accordingly.
