Visibility of Quilts in imported assemblies
Parts which are converted as Quilts (surface parts) are not visible when selecting the topassembly. They must be selected seperately to show them in a viewport. This seemed to be 'As designed' behaviour. However this is very confusing because you cannot see the parts when importing the assembly from Step or opening the assembly from Model Manager (same behaviour when deselecting the top assembly!).
Better behaviour would be to turn on visibility for all objects within a structure; because of the different color it's obvious which parts are solid and which parts are surface parts.
3 Comments
wdesmet
3-Visitor
i think this is possible. if you right click in the sturcture browser you can open the settings. go to the 4th tab drawlist and activate the option 'from owner to container'. i was not able to test this at the moment, but i think this is your solution
hvandenboomen
1-Newbie
Yes! this is the solution!
Thanks Ward for your help!
PTCModerator
Emeritus
Status changed to: Archived
