Visibility status of X-sections in combined states
Visibility status of X-sections is not saved when saving or updating combined states.
When you change this option for the combined state, the option change for the Xsec model views.
This option should be independent and should be save with the combined state.
2 Comments
PTCModerator
Emeritus
lwestbrook
Status changed to: No Plans to Implement
I don't quite see why this is a problem. The behavior seems consistent with the way that combined views work. For example, if I activate a combined view that references a simp rep, when I go to the simp rep tab, I can see that the corresponding simp rep is also activated. Same story for referencing a cross section in a combined view: when I activate the combined view, I can see in the sections tab that the section was activated automatically when the combined view was activated. So if the combined view sets a section as visible, it seems consistent that, upon activating that combined view, the section's visibility would be shown as visible in the Sections tab.
If I have misunderstood the request, or if you disagree with my above statements, please let me know. Until then, I will mark this request as "No Plans to Implement".
