Currently for my company, I cannot find a way to meet all use cases for how we utilize the notes after the Leader Orient or Tail as we call it, of the weld symbol if it is created through the Weld Application.
Note that we have customized our symbol to remove the REFERENCE which comes OOTB and drives weld sequence numbers after the tail. We replaced it with 2X which is our most common use of the notes after the tail. Users can easily change it to 4X, 5X etc. to represent that number of similar welds. This works great for us in 90% of our use cases. The problem is when we have a use case that needs either 2 lines or 3 lines of notes after the tail.
Example: I need this weld symbol to read as shown (Note that it was created as part of Weld Application tool):
Redefine symbol as shown:
Go back to symbol on drawing and there is no change.
As I see it, these are my options with current functionality:
What I propose is a text editor build in to the Weld Application feature that would allow user defined notes with different alligment options. Blue outline indicates selected option. I am sure there is a better way to do that but you get the point. We would always want the note centered but other companies may have different requirement. Recommend a config option to set desired default.
Example:
This would allow user defined notes that reamin parametric and help to drive best modeling practices by making Weld Application more user friendly.
If you made it this far thank you for your attention and please vote for this Product Idea.
Jason Knighten
